  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Settings question
Y'know when you navigate through the box (search, select a show etc.) it makes a "breep" sound on every click.  How do I turn that sound off? - It's driving the wife batty 😉
I thought it would be in the settings but I can't find it (I'm probably looking right at it.)  I have the buzz 4000 box - I really like it!!
Ahhh It's "System" sounds - I thought that would turn off the sound to the whole system.
I was looking for "Navigation" sounds.
Thanks!!
