November 1, 20197 yr I had an issue with setting up box for first time. Went thru all settings . Initialization etc , internet. Then I went to setup the server credentials. I used streaming line. Was getting an error can't connect to server error. I went to the network connection settings. Noticed it said my ethernet waas not conn connected. it was hardwired. Toggled the wifi off then on. It showed connected. Then I tried to connect to the server . It was fine now
November 1, 20197 yr Author There's an issue with the streaming line, m3u line setup. I guess it's not fully implemented. I guess I'll have to use mac id setup
November 1, 20197 yr 15 hours ago, SloppyJoe said: I had an issue with setting up box for first time. Went thru all settings . Initialization etc , internet. Then I went to setup the server credentials. I used streaming line. Was getting an error can't connect to server error. I went to the network connection settings. Noticed it said my ethernet waas not conn connected. it was hardwired. Toggled the wifi off then on. It showed connected. Then I tried to connect to the server . It was fine now this error message means you entered the wrong URL or wrong username/password combination
November 1, 20197 yr Author No a new update is supposed to be released. M3u / streaming lines are not functional. I've been doing this on many other units np
